Wider-angle Toyota head (4A-GE): 50-degrees (http://www.billzilla.org/chamber.jpg) | Honda head: (http://www.billzilla.org/vteccut.jpg) |
So when comparing the differences, consider the rod to stroke ratio too.What? なに? これはなんですか? The rod is dimensionless, only the stroke of the crank determines the distance the rod will travel.
Still, rhe best for revving, I believe, is an oversquare bore/stroke, with a long rod.Interesting! That is what the 2ZZ has and the 4A and S2000 engine do not have! Man this is such an interesting thing to think about :yesnod:
A short rod/stroke ratio works best in the lower RPM ranges.Isn't it the other way around? If you have a longer stroke, then the time at which the piston remains at TDC is increased, so more pressure is developed. The only bad side is that the longer stroke will also cause the piston to travel back down the bore with much greater velocity than compared to a short stroke... They should come up with a variable stroke engine. So at lower RPMs you could have a longer or shorter stroke, and as you rev the stroke changes. Wow that would be sweeeeeeeeet
