nzae86's AE86 N2 Race Car Project [LOTS OF PICS]
Started by BigMike, September 25, 2010, 09:39:07 PM
Previous topic - Next topic
I spent soooo much time reading through this thread I wanted to mirror and share it here. This is the sort of build I want to do to a 1985 MR2 someday. From the frame-up, complete build like this 8)
The goal of this project:
Target weight will be 800 kg (1,764 lbs)
The original thread is over 16 pages long.
I'll cut through all the bullcrap and just post the important stuff :D
-/_/___/__________\___\_\-
|______________________|
|-------\___________/------|
R135
  246
#1
[JAN 2008]
First he built a cage
Picked up a real Formula Atlantic engine
Here is the forged crank compared to a small port SC & 20-valve crank
Engine parts
Mocking it up
Staying true to the early Carburated Formula Atlantic specs
The inlet and exhaust cams are both 320 deg with 10.6mm lift TRD #881
He couldn't find an original flywheel, so he had this one custom made
Twin plate Quartermaster 71/4 inch clutch
R135
  246
R135
  246
Everything he bought was straight out of the TRD N2 Manual
TRD Shocks
Complete with Tein strut tops
Front Caster Rods
TRD Sway Bars
R135
  246
Brand new TRD 5.3:1 R&P
The real N2 cars ran Diff coolers. Here is his setup for this
Brand new TRD Transmission gear set
He couldn't find new TRD engine mounts, so the next best thing were these Cusco mounts
R135
  246
Various parts
Koyo radiator
TRD Header
TRD Dry Sump Kit
R135
  246
Here is how much of the body is being cut for the wider wheels
The measurements for all of this were taken straight out of the TRD N2 Manual
Cut for Fuel Cell. He offset it opposite the TRD Manual for better weight distr.
R135
  246
Check out these car holders. THIS IS AWESOME
He says he has been collecting Corolla's for over 12 years
Here are some other cars he owns
Ton of parts
He also owns a GT3 or something GEEEEEEZ
R135
  246
#8
Got the interior stripped out
He "made" this himself out of fiberglass
[APRIL 2008]
He took the shell down and had the paint stripped and had it primed
R135
  246
Building parts to strengthen the cage
The templates
The final piece
Installing...
R135
  246
Check this out, he really does have a complete TRD N2 Manual.
Here he is test fitting the N2 body kit
and with his custom hatch installed
R135
  246
Suspension links
Got the cage primed
Starting on the rear axle
These are genuine Toyota axles made for a LSD diff
He noticed the shell had some bent parts, so he cut them out and replaced them using parts from a donor car
R135
  246
Here is the rear end coming together
Check out how awesome it is to just flip the shell over using that awesome car holder. WOW that is SO NICE
Flipped up-right
Front end coming together with caster rods
Test fitting more stuff
He says the car will sit much lower once everything is installed
R135
  246
#13
[MAY 2008]
Test fitting the engine
Discovered the TRD dry sump interfers with the steering rack
He continues to coment on how important and helpful it has been to test-fit stuff
R135
  246
#14
Getting the fuel tank installed
Made some home-made plate for the project 8)
[NOVEMBER, YES NOVEMBER 2008]
Starting to come together
[FEB 2009, YES 2009]
Here he is building his own custom fiberglass hood
Look at the rolls of fiberglass he has. WOW
Making the molds
Got it finished
R135
  246
