Author Topic: Project P.O.S.  (Read 23954 times)
Offline Sirdeuce
  • LeMons
  • Hero Member
Project P.O.S.
« on: March 10, 2012, 08:49:22 PM »
1987 Corolla FX16. Gettin' it back on th' road. Little car has been sitting for about four years, let's see how it goes. First thing was to make sure the engine would still run. Check fluids, drop in a battery and turn the key. After a few seconds of cranking, the engine came to life. SWEET! It  runs! Now to fix the reason for parking it in the first place. Motor mounts were all broken and the shocks are dead.
The motor mounts are the first chore. Ordered, received and installed. Installed, but not without a few problems. First, the mount for the front of the engine was wrong. Not too bad to fix, as I simply had to change the bracket bolted to ther block. Had one the was right for the mount, done deal. Tranny hanger, no problems. Dropped the crossmember, bolted the new mounts to the brackets on the tranny, bolted the crossmember in place. Now I see why the mounts all broke together. The brackets on the trans were installed wrong! The front to the rear and so on. The entire powertrain is pushed forward about an inch! Reinstalled the mounts in the proper places and everything fit pefectly. Started the car to move it back to it's place in the driveway. What a difference! Right from the start I could hear a huge difference in the noise transferred to the chassis. I'd drivin this car for a few years this way, it was so noisy!.
« Last Edit: March 13, 2012, 08:17:39 PM by Sirdeuce »
Offline Sirdeuce
  • LeMons
  • Hero Member
Re: Project P.O.S.
« Reply #1 on: March 10, 2012, 08:59:17 PM »
Next on the agenda is the struts. I have a Ground Control spring set for the P.O.S. . Need to cut the top of the struts off and weld on the screwed strut tops from an MR2 I have laying around so I can install cartridges. The engine has a modded TB already, headers, intake, cams and things should be doing good. I'll get pics on the strut mods as they come to be. Have to learn to operate the wife's camera, washed mine in the ocean and can't do a thing with it.
By the way Mikey, this engine is the one I had in my MR2 when you had your ITBs!
Offline BigMike
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
Re: Project P.O.S.
« Reply #2 on: August 20, 2012, 08:53:21 PM »
I love the goats on the car!! haha
-/_/___/__________\___\_\-
|______________________|
|-------\___________/------|
R135
  246
Offline BigMike
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
Re: Project P.O.S.
« Reply #3 on: August 20, 2012, 08:53:40 PM »
:worthless: :worthless: :worthless:
R135
  246
Offline Sirdeuce
  • LeMons
  • Hero Member
Re: Project P.O.S.
« Reply #4 on: January 23, 2013, 11:24:00 AM »
The P.O.S. is now a white 1987 FX16 GTS. Arrived so far are the Whiteline sway bars and urethane bushings. In the process of installing them currently. Awaiting news on availability and price of coilovers, maybe BG from Great Britain, we'll see. Fall back on the Ground Control if I have to. Sorry Mike, no camera, no pics.
Offline Sirdeuce
  • LeMons
  • Hero Member
Re: Project P.O.S.
« Reply #5 on: February 04, 2013, 06:49:54 PM »
Ordered the BC coilovers today!!
Offline BigMike
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
Re: Project P.O.S.
« Reply #6 on: February 11, 2013, 04:02:57 PM »
:popcorn:
R135
  246
Offline BigMike
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
Re: Project P.O.S.
« Reply #7 on: April 28, 2013, 09:19:34 PM »
UPDATES?!?! :hyper: :hyper: :hyper:
R135
  246
Offline Sirdeuce
  • LeMons
  • Hero Member
Re: Project P.O.S.
« Reply #8 on: May 03, 2013, 08:48:32 PM »
Still waiting on flippin' parts. Seems ordering from G.B. takes awhile.
Offline BigMike
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
Re: Project P.O.S.
« Reply #9 on: May 07, 2013, 06:56:55 AM »
:popcorn:
I missed your call over the weekend. What's up?
R135
  246
Offline Sirdeuce
  • LeMons
  • Hero Member
Re: Project P.O.S.
« Reply #10 on: June 26, 2013, 08:54:34 PM »
Finally! 2 months overdue, but they finally got here. The struts are finally here  :applaus: now let's see how long it takes me to install them.
« Last Edit: June 27, 2013, 09:29:55 PM by Sirdeuce »
Offline BigMike
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
Re: Project P.O.S.
« Reply #11 on: July 21, 2013, 10:33:00 AM »
UPDATES :hyper:
R135
  246
Offline Sirdeuce
  • LeMons
  • Hero Member
Re: Project P.O.S.
« Reply #12 on: July 24, 2013, 11:25:33 AM »
Ran into a few snags. Going to replace front axle bearings, install longer wheel studs and use 10mm spacers to get clearance for running negative camber. Tires rub at max neg camber setting. Whiteline bushings are in. Whiteline sway bars are in. Installing WEB cams 294 grind and detailing a few items in the engine bay. The heat has boiled my motivation away though, so 2 more weeks.
Offline BigMike
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
Re: Project P.O.S.
« Reply #13 on: August 14, 2013, 01:53:18 PM »
R135
  246
Offline Sirdeuce
  • LeMons
  • Hero Member
Re: Project P.O.S.
« Reply #14 on: August 24, 2013, 08:51:15 AM »
Bearings are ordered. Why am I not excited about getting this thing on the road??
