Christmas & New Years was right around the corner so I didn't return to this project for a few weeks. During that time I was able to find some N/A MK2 axles locally. Here they are, 1 long side and 1 short side. ummm, errr well that is what they "said" they were
I ended up with two short side axles, but they were a bit different: One was about an inch longer, and the other had a smaller nut thread. The splines were the same, but I still had to source a proper long side axle.
So on with finishing up the trans!
Jan 16, 2011 - Finishing up the 6 speedI was looking over the trans and realized that I had a shift rail in wrong and the trans would get locked into two gears at once. Ho Hum. Yeah.... It's been
that kind of a job. So back apart it comes....
...I lost count on how many times I had to break the silicone seal and rip into the trans. It was really bad. And each time I had to remove that cracked 5th-6th gear hub, which was really troublesome because come to find out the dealer has a national backorder on that ~$100 hub. So if I jacked that hub then I'd really be SOL for a while....
Here is a good closeup shot of the C60 diff
Then, lastly, I put everything back together with cleaned sealing surfaces and fresh silicone and what did I find sitting on the bench.......................
.....................the dang stock internal magnet. SHEEEEEEEEEEEEEEEESH.
So I had to tear it apart YET AGAIN
