Bevin's MGB Motivational Thread
Started by BigMike, June 02, 2010, 07:13:19 AM
Previous topic - Next topic
Sirdeuce
All I can muster on that 513 hp is a barely perceptable, gutteral, evil chuckle!
Bevin, ya got any of this white stuff at your place?
-/_/___/__________\___\_\-
|______________________|
|-------\___________/------|
R135
  246
Sirdeuce
Did I start something here? How about the hayabusa V8?
Sirdeuce
Okay Bevin,
Here ya go
If these guys can do crazy builds like this, then so can you :best:
Here is a mid-engine Prelude conversion, this is an exact option you are considering:
http://www.preludeonline.com/f82/new-here-mid-engine-rwd-prelude-238311/
http://www.myspace.com/team_x_mpls
Look ma, no engine:
And here is some crazy wacko who swapped in a V8. Check out the work he did. You can do this type of work to the MGB and get a Prelude engine in there in a rear-wheel drive configuration :_order:
http://honda-tech.com/showthread.php?t=1645997
Here is the rear independent suspension being built. I don't know what it is out of, you'll need to read the thread for the details...
HOLY CRAP, I just discovered that thread is 32 pages long!!! Sheeeesh!
R135
  246
Ok,
I found out the red prelude with the V8 conversion is using a RX7 rear suspension. Also, he abandoned the project and parted out the car. Dang that was a lot of work for nothing...
R135
  246
Blane525
#51
OK OK :yikes: after this you big mike will have to have yournhead examined THAY IS A TURBO!!!!!!.. :doh:
Blane525
#52
yes Bill the Snow was not that substantial only left a trace and was gone. well thanks for all the :willynilly: over the top ideas  but when one drives a Cadillac with a vw pocket book he will soon be :outtahere: in a cell with :tantrum: Burnie Maidolf (SP) :rofl:
Quote from: BigMike on November 22, 2010, 12:43:46 PM
Ok,
WOW BLANE, Check this out: http://www.solomiata.com/Drivetrain.html tons of Mazada drivetrain info!
Complete RX7 Rear end: Just do some fab work and weld it in place :thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
R135
  246
Quote from: BigMike on November 22, 2010, 08:09:51 PM
Yup, I think this is how you should do it. Get some sub-frame assembly like this that you can just retrofit under the MGB. The IFS will handle better, and you can still put in a limited slip and do some drifting :bowdown: :driving: :boobs: :burnout:
R135
  246
R135
  246
This one is some sort of a custom Lotus 7 rear end with a Mazada Miata differential:
If the image doesn't load, try this: http://lh3.ggpht.com/_GWYdF_g9c_g/SDRgE5QLzBI/AAAAAAAAACQ/5LP8MgeLaAA/s640/Caution%20Miata%20Rear%20Subframe_0550.JPG
R135
  246
Here is a Nissan 240SX rear subframe drop out:
Seriously, that doesn't look hard AT ALL to just drop under the rear of your MGB. The width of these are of course wider, so some modification will be required...
R135
  246
Here you go, a modified Jaguar XJ-6 rear subframe LOL
R135
  246
Blane525
well guess you did"nt read my early post on subject! cash baby cash...
