Author Topic: Toyota V-series V160 / V161 2jzge swap  (Read 13211 times)
Offline lyubomir
  • Newbie
    • Email
« on: July 08, 2010, 10:22:53 AM »
V160 Ratios:
    * First gear: 3.827:1
    * Second gear: 2.360:1
    * Third gear: 1.685:1
    * Fourth gear: 1.312:1
    * Fifth gear: 1:1
    * Sixth gear: 0.793:1
Applications:
    * May 1993 - August 1998 Toyota Supra Twin Turbo JZA80 Export Models
    * May 1993 - August 1997 Toyota Supra Twin Turbo JZA80 Japan-Spec Models
V161 Ratios:
    * First gear: 3.724:1
    * Second gear: 2.246:1
    * Third gear: 1.541:1
    * Fourth gear: 1.205:1
    * Fifth gear: 1:1
    * Sixth gear: 0.818:1
Applications:
    * May 1996 - July 2002 Toyota Supra Non-Turbo JZA80 Japan-Spec Model (SZ-R Grade Only)
    * September 1997 - July 2002 Toyota Supra Twin Turbo JZA80 Japan-Spec Model
While this is a very cost prohibitive swap, I feel that it would be ideal for my chassis (96 sc300) and stock 2jzge.
The 4 speed automatic transmission is anemic at best and chokes the engine completely, stripping away all the fun it could provide.
I have a fairly low mileage (127k) chassis with everything original in very good shape.
I'd like to retain the vehicle and make it a bit more fun to drive.
I've been having fun on highway ramps for the past 2 years, but I feel the biggest shortcoming of this car is the automatic transmission.
I'm afraid that I might have to settle for a 5 speed swap instead, because the V160 and V161 swap in hardware only will cost more than the value of the vehicle itself.
Let's hear what the gear-heads on this forum have to say.
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
Re: Toyota V-series V160 / V161 2jzge swap
« Reply #1 on: July 08, 2010, 11:26:57 AM »
If you can settle for a 5spd, you could always use a R154 using a 1JZ bellhousing to mount it to your 2JZ engine. This is what a LOT of Drag Racing Supra customers of ours do (yes, we build transmission for Drag Supras!!)
Here is our Race R154 that we sell to Supra owners. This has the 1JZ bellhousing that fits the 2JZ:
Product link: http://www.marlincrawler.com/transmission/rebuilt-complete/r154-2wd-race
and here is our Competition 2WD R150 transmission rebuild:
The gear ratios are as follows:
1st gear2nd gear3rd gear4th gear5th gear
R1543.2501.9551.3101.0000.753
R1503.8302.0621.4361.0000.838
We haven't put both feet in the Supra market yet, and still there are a lot of people talking about our Short Throws and upgrade parts for Supra transmissions.
We have a lot of upgrade parts for these...
Heavy duty center plates:
http://www.marlincrawler.com/transmission/parts-upgrade/heavy-duty-bearing-cover-plate
Heavy duty billet shift fork:
http://www.marlincrawler.com/transmission/parts-upgrade/billet-shift-fork-r-series
Heavy duty shifter seats:
http://www.marlincrawler.com/transmission/parts-upgrade/heavy-duty-shift-lever-ball-seats
Heavy duty shifter sockets:
http://www.marlincrawler.com/transmission/parts-upgrade/heavy-duty-shift-lever-socket
Heavy duty output seals:
http://www.marlincrawler.com/transmission/parts-upgrade/heavy-duty-transmission-output-seal
Heavy duty pressure plate bolts:
http://www.marlincrawler.com/hardware-tools/hardware/heavy-duty-pressure-plate-bolt-kit
Short throw kits:
-/_/___/__________\___\_\-
|______________________|
|-------\___________/------|
R135
  246
Offline Sirdeuce
  • LeMons
  • Hero Member
« Reply #2 on: July 08, 2010, 03:26:35 PM »
Going to have to change the company to Marlins Performance Gear.
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #3 on: July 08, 2010, 03:41:22 PM »
Oh yeah, we also offer Chromoly thrust washers that are not on the website at the moment
R135
  246
