NEW MR2!!!
Started by BigMike, March 21, 2010, 08:28:55 PM
Previous topic - Next topic
I helped Bill pickup this SA-WEET 1987 MR2 from Lemoore today 8)
It has a TRD header, HKS muffler, Nology Hotcore spark plug wires, a low mileage engine, low mileage transaxle, and new drive axles.
The Bill of Sale says Bill only paid $200 for it 8) 8) 8)
-/_/___/__________\___\_\-
|______________________|
|-------\___________/------|
R135
  246
The front and rear bumpers and the HKS exhaust muffler are in the back of the Tundra, and all the plastic trim and missing body panels, such as the drivers rear corner, are in the interior of the car. So everything is here to put it back together as much as we'd like to.
The only problem with this is that it is from Minnesota and has not been registered for a very long time. Registration fees would be stupid expensive + we'd have to pay import taxes since the car is out-of-state, so it looks like registering the car so we can drive it to AutoX might be out of the question.
I have a flat bed trailer I can toe the car to and from AutoX events, which is a huge burden and PITA, but it can be done. You'll notice I slapped my Truck license plate on the back just so we could tow it to Fresno like this (if any part of a car is touching the ground, it must be registered).
I 1,000% prefer the MR2 over a FX16, what do you guys think?
R135
  246
Sirdeuce
MR2, definately! But the FX would still be a lot of fun. We have a $300 window for parts now. Let's see what we can get for the extra parts on ebay. Now we need to post on this under the Bill's FX16 area.
Hey, we can sell those 17" wheels for $150 maybe? On second thought, they are pretty hideous, maybe $100 :D
R135
  246
Sirdeuce
I want the wheels for the FX16!!
Blane525
hay that thing is awsome mike you dont know anything about wheels do you without those things its just another pile. but this thing is rear wheel drive! looks great
Blane525
by the way the plate switch thing is a very bad idea it would be better to not have one. Being a felony to put the plate off of another vehicle! dont do that anymore. i would come visit you and send you five dollars a month for the commissary
well, at least they won't pull me over in the first place? Besides, I would just say the car is not mine and that Bill stole my plate and send his butt to jail hahahah
R135
  246
Sirdeuce
Lightening the 2
Start in the back, bumper, tail lights, PLATE, stock intake, cut out trunk firewall, remove bracing from decklid and trunk lid, trunk lid springs. Any non-structural metal can be lost. The engine compartment can lose the A/C compressor, and the battery tray, battery will bemoved to the front. Remove A/C and heater lines from the tunnel. We can use the oil for heating if need be. Gut the interior. Door seals and moldings can go. Cut all unecessary metal from the doors, could tack weld the passenger door skin in it's frame. Remove all unecessary elictrical wiring and accessories. From about he front firewall forward probably keep the geneeral weight. Just remove things not being used. Tack weld the light covers to the trunk lid. We can use the turn signal holes to get cooling air to the brakes. Any hole or gaps can be covered with tape. Any other ideas?
Quote from: Sirdeuce on March 27, 2010, 10:31:43 PM
Since we don't need windows or anything, we can even take it further than what this guy did
R135
  246
Here are pictures of the engine, nice and greasy and ugly, just what we want :)
Here are a couple close ups of the Nology Hotcore wires. I like the spider webs in the background.
I still need to take pictures of the TRD header. Big-K says it fires right up, purrs like a kitten, and has great throttle response. We need to get a new throttle cable.
R135
  246
In order to shave off more weight I had this idea.
This idea benefits in two ways:
  • Removes weight
  • Improves overall car balance (since it removes weight from behind the rear axle)
The hideousness of this alone could get us entered. I bet the judges would love it hahaha
So basically, remove everything from behind the rear firewall. It might be a challenge to get an exhaust system crammed in there somewhere. We'll relocate the ECU to the cabin.
If we are worried about getting rear ended, then we can add some inner armor to help with impact.
R135
  246
Sirdeuce
Actually, I thought about cutting out the trunk. I just thought you guys would think I had lost it altogether. As for the doors,  on the passenger side, just cut down to the outer skin and tack it to the body. The driver door can be cut almost as much, but still needs to retan some mechanism the secure it in the closed position. Dont need door glass, but if we need to we can use plexiglass. Only the windscreen is required to use stock glass or lexan. As far as getting hit in the rear,  the rules say we can't put structure outside the original body lines.
Any thoughts on shortening the front??
Sirdeuce
Integrate a "safety" cage in the back with the rear wing. Frankendeuce the car.
Quote from: Sirdeuce on March 29, 2010, 10:36:37 PM
That is a really great idea. I say let's do the same to the drivers door, and we'll all climb through the open window. Well, unless Bill and Bevin are too old hahahahaha :-X
That is okay, I was referring to adding support to the rear engine firewall, so internal structural reinforcement.
Kevin and I also tossed the idea around of turning the MR2 into a Pagani Zonda complete with a super-car pivoting engine cover, like this:
These ideas are purely to make us stand out from the rest of course, just to be different.
R135
  246
