Author Topic: nzae86's AE86 N2 Race Car Project [LOTS OF PICS]  (Read 46290 times)
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
Re: nzae86's AE86 N2 Race Car Project [LOTS OF PICS]
« Reply #15 on: September 25, 2010, 09:44:41 PM »
Got the seat mounted
Starting on the pedal assembly
Modified the floor to fit it all
Canister for dry sump oil setup
-/_/___/__________\___\_\-
|______________________|
|-------\___________/------|
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #16 on: September 25, 2010, 09:44:55 PM »
[MARCH 2009]
Removing everything to get it all painted up
He plugged the hole where the stock brake booster & master and clutch master were mounted
Started to sand everything down
Bought a ton of gauges
Took everything down to get electroplated
« Last Edit: September 25, 2010, 09:55:03 PM by BigMike »
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #17 on: September 25, 2010, 09:45:02 PM »
Here is some lexan he will use to build into lightweight windows
Building the windows here. Complete with black trim
Started on the TRD Gear Set. Here is his stock T50
Note how the TRD gears & shafts are SPLINED so you can interchange gears and also replace broken gears. N-I-C-E
Brand new parts for the rear axle
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #18 on: September 25, 2010, 09:45:09 PM »
Began to work on the rack and pinion so it will clear the TRD dry sump
Bunch of stuff to rebuild it with a closer ratio unit
Here is the Cusco mount with an electroplated cross member. Looks great
He decided to get the oil canister polished. Nice
Still working on the fuel tank stuff
Getting everything mounted
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #19 on: September 25, 2010, 09:45:24 PM »
Modifing the rear diff for the cooler & pump
[MAY 2009]
Here is the body back from the painter. LOOKS GREAT! I am really starting to dig Silver 1980s Toyota's
« Last Edit: September 25, 2010, 09:55:59 PM by BigMike »
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #20 on: September 25, 2010, 09:45:32 PM »
Here are the wheels he is going to use
They are 13" by 8" wide for the front, and 13" by 9" wide for the rear. His rear wheels are wider than the wheels on my Rock Crawler! DANG!
215mm wide front tires
240mm wide rear tires
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #21 on: September 25, 2010, 09:45:38 PM »
Starting on the decal work. Everything is Vinyl
Got the parts colored. WOW
NICE
Check out those lil 13" wheels
He is still hoping the car will be a lot lower
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #22 on: September 25, 2010, 09:46:02 PM »
Here are progress pics of the engine reinstalled into the painted shell
Here are his lexan windows installed
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #23 on: September 25, 2010, 09:46:13 PM »
Here is his T50 trany all put back together
TRD short throw shifter
Engine Oil cooler mounted
Working on the oil lines
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #24 on: September 25, 2010, 09:46:27 PM »
Working on the fuel lines
Got the fuel tank all done
[JULY 2009]
Here is the rear diff cooler mounted up
The cooler lines running to the rear diff
Took the rear diff back out to give it a new coat of paint. GEEEEEZ
« Last Edit: September 25, 2010, 09:57:06 PM by BigMike »
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #25 on: September 25, 2010, 09:46:36 PM »
Looking good here
Here is a high torque reduction started. Not sure why he would need this...
Then he decided to use this awesome "Stack" dash instead of all those Autometer gauges
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #26 on: September 25, 2010, 09:47:05 PM »
Then he decided to switch to an EFI setup
Off with the rebuilt carbs
Blurry pic of the intake runners
Slapped on a TRD manifold
He made the switch to EFI because he found out that New Zealand is going to ban "100+ avgas" setups (carbs??) for motorsports.
He knows that the engine was built with carburation in mind, but he thinks with the right tuning it will do okay with EFI.
Here is has a heater box installed using some marine blower motor
Let the wiring work begin!
Reduced this:
To this:
Some lightweight batter
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #27 on: September 25, 2010, 09:47:21 PM »
Starting on the interior now. WOW
Switched to these seats for the improved neck support
Also switched to a different harness
Here is the seat mount
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #28 on: September 25, 2010, 09:47:31 PM »
Working on the intake now
He is using 460cc injectors
This box is pretty large
W-O-W
R135
  246
Offline BigMike
  • Administrator
  • Hero Member
  • Gender: Male
  • ハイオク
    • 1987 Toyota MR2
    • Email
« Reply #29 on: September 25, 2010, 09:47:40 PM »
[OCT 2009]
Here is a brand new laminated windshield installed
[NOV 2009]
WOW
WOW
The coil pack is from a Ford
« Last Edit: September 25, 2010, 09:58:21 PM by BigMike »
R135
  246
